Script or Macro to convert an array of glosses to a list
Postby dictdoc » Sun Apr 29, 2012 1:49 am
I have a database with the following structure:
Headword in a foreign language followed by frequency (delimited with comma) and eventually followed by a list of glosses in English, each gloss delimited with a comma. A small sample is given below
कुर्यवंशी,4,kuryanshi,kuryavanashi,kuryawanshi,kurywanshi
कुर्रे,2,kurray,kurre
कुलदिपकर,2,kuladipakar,kuladipkar
कुलदीपसिंग,4,kuldeepsing,kuldeepsingh,kuldipsing,kuldipsingh
कुलभूषण,2,kulbhooshan,kulbhushan
कुवरसिंग,4,kuvarsing,kuvarsingh,kuwarsing,kuwarsingh
कुशवाह,3,kushavan,kushawah,kushawaha
कुशवाहा,2,kushavah,kushavaha
कुशाबराव,2,kushabrao,kushabrav
कुशेश्वर,2,kusheshvar,kusheshwar
I need a script or a macro to convert these into the following format. The first item from the example is given as a converted item.
कुर्यवंशी,4,
कुर्यवंशी=kuryanshi
कुर्यवंशी=kuryavanashi
कुर्यवंशी=kuryawanshi
कुर्यवंशी=kurywanshi
The macro I have written is too slow and takes a large amount of time. Basically the macro selects the headword. Pastes it onto a next line, chooses the first gloss (deletes it), pastes it onto the headword on line 2, preceded by an equal to sign and carries on till all the glosses on a line are exhausted. The process is repeated till all the headwords are exhausted.
The macro takes ages , since the glosses for a single headword are considerable and also because there are a large number of headwords.
Any way of speeding the process up would be gratefully acknowledged.
Many thanks
dictdoc
Re: Script or Macro to convert an array of glosses to a list
Postby Mofi » Sun Apr 29, 2012 11:22 am
Okay, a macro doing this transformation faster.
UltraEditReOn
Loop 0
Find RegExp "%^(*^),^(?+^),^(*^)$"
Replace All "^1,^2^p^1=^3"
IfNotFound
Find RegExp "%^(*,*^)$"
Replace All "^1,"
The regular expression in the loop executed until no replace done anymore, combines the string from start of line to first comma, with the string after last comma to end of line in a line below while removing the string after last comma. By doing this replace in a loop all English words are removed from the line with the number. The last regular expression replace all appends the comma after the counting number after making the transformation to get exactly the result you want.
Postby dictdoc » Sun Apr 29, 2012 8:23 pm
Dear Mofi,
The macro works like a charm. It replaced 40,000 rows in around 48 seconds approximately. Many thanks for saving precious time.
dictdoc
