I occasionally have to build array definitions for VBA in the form
Array(1) = "Some Text"
Array(2) = "Some More Text"
and so forth.
I wrote the following macro to help me do this. It assumes the current document contains the text you want in quotes, on separate lines. As in:
Some Text
Some More Text
Yet Another Line
The macro creates an empty file, sticks one blank line in it for each line in the current document, then uses the ColumnInsertNum to generate the array indices. It then repeats back through the current document, modifying the lines as appropriate. It quits when it reaches the end of the array indices file.
I suspect the execution time of this macro would be large if the files were large, but I typically use this on files of 30 lines or so, so it's not too bad.
It will work with numbers - just use search and replace to remove the quotes.
The macro is:
NewFile
PreviousDocument
IfEof
NextDocument
InsertLine
PreviousDocument
Key DOWN ARROW
NextDocument
ColumnInsertNum 1 1
PreviousDocument
NextDocument
IfEof
CloseFile NoSave
SelectLine
Cut
PreviousDocument
"Array("
Key BACKSPACE
Key END
Key DOWN ARROW
Key HOME
Have fun....
Bob
