Delete line if does not start with a specified character or word
Postby Javier » Fri Sep 09, 2005 9:44 am
I need to delete all lines in a text file that doesn't start with "@".
For example
FFFFFF
@GGG
AAAAA
@BBBB
should result:
@GGG
@BBBB
i'm trying with IfnotFound but I'm getting errors.
any help? thanks
Javier
Re: Delete line if does not start with a specified character or word
Postby mrainey56 » Fri Sep 09, 2005 10:47 am
Do a regular Search/Replace All
Regular Expressions checked (Unix-style)
Find What: ^[^@].*\p
Replace With: nothing
mrainey56
Postby Javier » Fri Sep 09, 2005 11:00 am
I've edited the next macro but it's not working
UnixReOn
Find RegExp "^[^@].*\p"
Replace All ""
Is this correct?
Edit: RegExp parameter was missing.
Javier
Postby Doug E » Mon Nov 17, 2008 3:51 am
Using this thread to modify my own macros I've come up with the problem..
When I search for ^[^@].*\p in a file containing the lines...
FFFFFF
@GGG
AAAAA
@BBBB
it works properly showing me the lines...
FFFFFF
AAAAA
But when I use it for my own purposes I try searching for ^[^http].*\p in the lines....
http://www.www.com/
http://www.www.com
ftp.www.com
http://www.ftp.com
And I get an UltraEdit popup saying...
Search string '^[^http].*\p' not found!
I am sure to check Unix Regular Expressions so what fundamental gap in knowledge am I missing here?
Doug E
Postby pietzcker » Mon Nov 17, 2008 7:47 am
[^http] means "Match any one character except h, t or p". So your regex should match ftp.www.com (and it does for me in v14.20.0.1035). However, it will also match a line like "this line starts with a t".
What you want to do requires Perl regular expressions.
^\s*(?!http).*\r\n
will match a (DOS file) line that doesn't start with "http" (leading whitespace ignored).
pietzcker
Postby Doug E » Mon Nov 17, 2008 10:49 am
Ahh, beautiful. Thanks pietzcker!
I spent much of the night reading how to do it with unix expressions. I'll have to read up on perl next.
Some keywords to help people find it: find word at start of the line cut it select line out paste it into new file txt
And the description of what it does...
Searches for lines that don't start with desired words (http in this case), selects those lines, cuts them out and pastes them into a newly opened file so you can review what was removed from the original file.
Show Cancel dialog for this macro: unchecked
Continue if search string not found: checked
PerlReOn
Loop 0
Find RegExp "^\s*(?!http).*\r\n"
CutAppend
NewFile
Doug E
