I looked for %line% and %col% analogy in macro. Thanks Bernd's solution in the yet not existing IDM forum anymore I've survived.
Now I found new possibility which works without the file size limits:
I configured Advanced -- Tool "GetPosition" as:
echo /%line%/%col%
with options (x)Create New File, [x] Capture Output,
and created macro GetPosition as
RunTool "GetPosition"
SelectLine
Key LEFT ARROW // It is because ECHO adds space to output
Key LEFT ARROW
Cut
CloseFile NoSave // If you find better capturing of output, let me know
ExitMacro
I'm hoping that Ian will release way, how to use the %xx variables via template or macro.
Pavel
