Problem with MatchBrace
Postby rdsidan » Mon Nov 29, 2004 11:51 am
I've got the following in my script to delete several sections of a text file that are braced:
MatchBrace
Key DEL
IfEof
My problem is that after is successfully deletes the first brace section, it doesn't go to the next section...it just starts 'slowly' deleting text one character at a time.
If I try to manually do a Brace command (using CTRL+B) is doesn't always work unless I page down a few screens and the brace section is visually displayed on the screen (of course this doesn't help the macro problem)
Any ideas?
Dan
rdsidan
Re: Problem with MatchBrace
Postby Mofi » Tue Nov 30, 2004 3:22 am
The problem is, that matching brace will not work as excepted, when a closing brace is found without an opening brace. For example a command like // 1.) will stop matching brace at ).
Also your macro is not working correct, if after deleting the last matching brace selection the end of file is not reached (for example comment at end of file). This modified macro will do the job maybe better.
MatchBrace
IfSel
Delete
Key RIGHT ARROW
IfEof
