I am running under windows vista business edition
I have a frequently repeated operation that I want to automate. Ideally, the script would do all of the following:
1) Open all the .html files from my c:/TEMP folder (circa 20 files) - a workaround would be to drag and drop files into uedit
2) Convert all the open files to DOS files (without having to answer the nags)
3) Convert all the open files from unicode to ASCII - I see only how to do this with one click per file
4) Save all the newly converted files on top of the originals(without having to answer the nags) - close all would seem to do this, somehow I am finding that the changes are not being saved
Any help would be appreciated
