IBM Carriage Control (ASA) Formatting
Postby is2gu » Tue Apr 10, 2007 2:46 pm
I have a number of files that have ibm carriage control codes in first column.
How do I create a macro that can replace the codes with the appropriate line feeds and eliminate the extra column?
The codes in column 1 are:
blank Advance one line
0 Advance 2 lines
1 Advance 1 page
- Advance 3 lines
+ Do not advance
is2gu
Re: IBM Carriage Control (ASA) Formatting
Postby Mofi » Wed Apr 11, 2007 6:42 am
You can't really expect an answer with that poor description. Post an example before and after macro execution enclosed in [code][/code] to help us to understand what you want.
Postby jorrasdk » Mon Apr 23, 2007 10:00 am
Was waiting on is2gu to get back, but as I am quite familiar with ASA control characters:
http://en.wikipedia.org/wiki/ASA_carria ... characters
I offer this solution:
Textfile with ASA control chars in 1st column:
1first line
0third line
+           overlay on third line (not supported, but deleted)
-sixth line
 seventh line
1new page, 1st line
 Second line
0fourth line
After "expanding" the ASA control chars:
first line
third line
sixth line
seventh line
^b
new page, 1st line
Second line
fourth line
The "^b" is replaced by the actual page break control char.
Here is the macro (could be named "asaexpand"):
Find RegExp "%[+]*^p"
Replace All ""
ColumnModeOn
Key Ctrl+END
Key HOME
Key RIGHT ARROW
Key SHIFT
SelectToTop
Key HOME
Find "1"
Replace All SelectText " %%%newpage%%%"
Find "0"
Replace All SelectText "^p "
Find "-"
Replace All SelectText "^p^p "
Key DEL
Find "%%%newpage%%%"
Replace All "^b"
IfCharGt 32
Key DEL
Please note, that I use "^p" so the text file should be DOS format (Use File / Conversions if not, or change the macro accordingly )
