"Batch" function to apply a macro to multiple text files
Postby DiamondEagle » Wed Apr 25, 2007 12:11 pm
I've written a macro that will apply some formatting rules to text files. I now need to apply the macro to a few hundred text files in various directories on a server. I need to iterate through all the folders on the server and apply the macro to each of the text files in each of the folders, eg:
\\serverX\2007\Jan (contains 100 text files)
\\serverX\2007\Feb (contains 200 text files)
\\serverX\2007\Mar (contains 500 text files)
\\serverX\2007\Apr (contains 200 text files)
So, there are a total of 1000 text files in the folders in the \\serverX\2007 directory. I need to run the macro on all 1000 text files.
Is there a "batch" command in UE that will allow me to go through each of the folders and apply the macro to all the text files in these folders?
DiamondEagle
Re: "Batch" function to apply a macro to multiple text files
Postby jorrasdk » Wed Apr 25, 2007 3:31 pm
Hi DiamondEagle
If you searched forum for "batch" you will see several discussions of invoking UE in command line mode and specifying a file list to open and macro to invoke - see for instance:
Search & replace macro from a list of file names
But I have used another approach several times - but it is only possible for UE13 !
Under "Advanced / tool configuration" I have made a tool called "DIR" with performs a simple DIR dos command :
DIR /A-D-H-S /B /S C:\temp\work\*.xml %modify%
(see DIR /? for explanation)
Tool options: Create new file, capture output, %modify% = popup box with command line
The macro I want to use on multiple files is assigned in "Macro" "Set macro for file load/save". I use "..on load" 1 times.
You might want to guard against this macro being invoked on unwanted files - for example use a test with IfExtIs (tests extension)
IfExtIs "xml"
"DO STUFF"
To process multiple files with the macro of choice, I then use this script:
//batchInvokeMacro.js
//Configure a tool called "DIR" that performs a DOS DIR command (see in findDirFiles)
var CRLF = "\r\n";
dirFiles = new Array();
findDirFiles();
if (dirFiles.length>0)
  performBatchProcessing();
// Call tool "DIR" which make
// dir /A-D-H-S /B /S root-filepath/filemask
// (no dirs, no hidden, no system, short list, subdirectories)
// root-filepath/filemask of your choice (eg. c:\temp\*.txt)
// tool should capture DOS output to new file
function findDirFiles() {
   UltraEdit.runTool("DIR");
   dirDoc = UltraEdit.document[getActiveDocumentIndex()];
   dirDoc.selectAll();
   var dirOutput = dirDoc.selection;
   dirFiles = dirOutput.split(CRLF);
  UltraEdit.closeFile(dirDoc.path,2);
/* loop through files and do processing of your choice */
function performBatchProcessing() {
   for (i=0;i<dirFiles.length;i++) {
      if (dirFiles[i].length>0) {
         UltraEdit.open(dirFiles[i]); /* Open file, load macro "fires" */
         UltraEdit.closeFile(dirFiles[i],1); /* save and close */
/* Find the tab index of the active document */
         tabindex = i;
         break;
   return tabindex;
Remember to remove your "..on load" macro option if this was a one time job.
Now adjust the above to your situation and then go get a cut of coffee while the script works its way through a 1000 files. I hope you found some inspiration in this.
Cheers, jorrasdk
Postby maryv » Thu Apr 26, 2007 5:30 pm
Very slick! Nice work, jorrasdk!
maryv
