How to Loop Action in MultiSelctionLine?
Postby carsonwen » Mon Dec 27, 2004 9:44 pm
Help~~
I encounter a problem.
When I select multiLines in UE, I want to add a String "'//" to start postion of each line I was selcted.
I wonder if the UE macros can do it?
e.g.
AAAAAAAA
BBBBBBBB
CCCCCCC
DDDDDDD
When I Select the middle two lines, my expectant results is
AAAAAAAA
'//BBBBBBBB
'//CCCCCCC
DDDDDDD
Help!!
carsonwen
Re: How to Loop Action in MultiSelctionLine?
Postby Mofi » Tue Dec 28, 2004 3:41 am
If you have syntax highlighting active for this and line comment is defined with '//, simply use Comment Add from menu Edit.
But here is also the macro for that job:
Find RegExp "%^(?^)"
Replace All SelectText "'//^1"
Postby carsonwen » Tue Dec 28, 2004 8:42 pm
Thank you for help!
Your Macros is well done!
Any way, I have another corresponding problem, I need another macro to remove the comment.
for example:
AAAAAAA
'//BBBBBB
'//CCCCCC include several space
'//'//DDDD'//
EEEEEEEE
when i multiSelect the five lines above, my expectant results is :
AAAAAAA
BBBBBB
'//DDDD'//
EEEEEEEE
It only remove first comment string for each line!
Please help again, I just a new user!
Thank
carsonwen
Postby Mofi » Thu Dec 30, 2004 3:16 am
Same method for removing as for adding:
Find RegExp "%'//"
Replace All SelectText ""
