Hide non-bookmarked lines
Postby rmfought » Mon Aug 27, 2007 1:40 pm
Hi, I'm using UltraEdit to review log files, and I have bookmarked lines of interest. Now I wish to hide all lines that are NOT bookmarked. Is there an easy way to do this?
rmfought
Re: Hide non-bookmarked lines
Postby Mofi » Tue Aug 28, 2007 1:42 pm
As workaround you could use the macro I posted at Copy to clipboard bookmarked lines? to copy all bookmarked lines to a new file. Append the commands
NewFile
to the macro and you have a quick solution. I will try to write a macro which uses command HideOrShowLines to hide (most) lines not bookmarked.
Postby Mofi » Tue Aug 28, 2007 2:42 pm
Here is the macro to hide (most of) all lines not bookmarked. I hope, I got all special cases and it works for all settings and versions. The macro is for UE v12.20 and UES v6.10 or any later. For previous versions delete the red marked bookmark numbers -1 and it should work too.
Bottom
IfColNum 1
Key UP ARROW
GotoBookMark -1
IfEof
ToggleBookmark
Bottom
PreviousBookmark
IfEof
ExitMacro
GotoBookMark -1
Key HOME
IfColNumGt 1
Key HOME
"ÿ"
Bottom
PreviousBookmarkSelect
Key HOME
IfColNumGt 1
Key HOME
Key DOWN ARROW
IfSel
Key UP ARROW
HideOrShowLines
Key UP ARROW
IfSel
Key HOME
IfColNumGt 1
Key HOME
IfCharIs "ÿ"
Delete
SelectToTop
IfSel
HideOrShowLines
