Finding vals in delimited text, copy line, replace some text
Postby cfay » Wed Sep 12, 2007 7:49 pm
I am new to macros and have been reading up on how they work. Because I need to get this project done, I was thinking I should post this question and see if someone might be able to point me in the right direction. Once I get into these macros, I am sure I will be able to build and learn.
Anyway, here is the deal:
I have 100's of files. They have comma delimited text and the beginning of each row looks like this:
0,0,"DOC","014","000031108.doc","","","",
0,0,"DOC","014","000031109.doc","","","",
0,0,"DOC","014","000031110.doc","","","",
0,0,"DOC","014","000031111.doc","","","",
28,0,"ZIP","014","000031112.zip","","",""
28,0,"SCC","014","000031113.scc","","",""
28,0,"TSV","014","000031114.TSV","","",""
28,0,"TXT","014","000031115.TXT","","",""
28,0,"TSV","014","000031116.TSV","","",""
0,0,"IDX","014","000031117.idx","","","",
29,0,"ZIP","014","000031118.zip","","",""
29,0,"MF","014","000031119.MF","","","","
29,0,"CLASS","014","000031120.class","","
29,0,"CLASS","014","000031121.class","","
What I need to do is search the third column for certain extensions, being ones that I want to exclude. I have a list of these extensions. Examples from above are IDX, CLASS, and SCC.
Once I find a row that has one of those extensions, I want to copy that whole line to a new file (all rows into 1 file)
Then I want to replace the third, fourth and fifth columns with replacement text - always the same.
So this:
would become this:
29,0,"TIF","","PlaceHolder.TIF","","
Does this make sense? I have been reading a bunch of your posts and I am guessing this will be a breeze for all you experts. Since I have never made a (successful) macro in ue, I have not gotten there yet.
Any help is greatly appreciated!
cfay
Re: Finding vals in delimited text, copy line, replace some text
Postby cfay » Thu Sep 13, 2007 1:31 am
Well, I am not sure if I just need to be patient for someone to be able to reply or I just explained poorly. Anyway, I have a macro that partly works. If anyone can help with the issues, I would love it.
Here is what I have:
ColumnModeOn
Find "TIFF"^p"
Replace All ""
Find "Hold"^p
Replace All ""
Find "CollectionID=0"
Replace All "CollectionID=1234"
Find "DocumentTextFile"^p
Replace All ""
Find "ExternalID=31"
Replace All "ExternalID=15"
Find "mar"
Key HOME
Key SHIFT
Key END
Open "\\Path1\Path2\Vol007\Copy of Vol007-ExcludedFiles_IncludedRecords.txt"
Bottom
IfColNum 1
CloseFile Save
Find "scr"
Key HOME
Key SHIFT
Key END
Bottom
IfColNum 1
CloseFile Save
Find "dms"
Key HOME
Key SHIFT
Key END
Bottom
IfColNum 1
CloseFile Save
Find "mid"
Key HOME
Key SHIFT
Key END
Bottom
IfColNum 1
CloseFile Save
Find RegExp "0,"scr","*","*.*""
Replace All "0,"TIF","","ExclusionPlaceHolder.TIF"
Find RegExp "0,"mar","*","*.*""
Find RegExp "0,"dms","*","*.*""
Find RegExp "0,"mid","*","*.*""
The only problem that I have is that it is copying lines that are not to be excluded. It also leaves an extra line between each exclusion line that it copies out.
Anyone? Anyone? Bueller? :D
lol. Thank you,
cfay
Postby pietzcker » Thu Sep 13, 2007 6:43 am
Hi, I'm no macros expert, but I can give you a (Perl style) regex that should find only the lines you want.
^(\d+,\d+,)(?:"(?:IDX|SCC|CLASS)","[^"]+","[^"]+")(.*)$
should work. It will capture the first two columns into backreference \1, ensure that the columns 3-5 match and capture the rest of the line into \2.
So you could search for the above regex and replace with
\1"TIF","","ExclusionPlaceHolder.TIF"\2
If I do this search/replace manually in your example code, it works without creating extra line feeds.
HTH,
Tim
pietzcker
Postby cfay » Thu Sep 13, 2007 12:04 pm
Thanks, I will look at this, although I have never gotten into perl, even a little. Will this copy the line to another file? It looks like perl will let me specify all extensions with a pipe delimiter. I think I can do this, but wanted to understand the part that copies the lines to the other file. Do I put this in as a new macro in ue?
Thank you, :lol:
cfay
Postby jorrasdk » Thu Sep 13, 2007 4:02 pm
It's not Perl, it a regular expression as implemented in Perl. Nothing here copies anything anywhere. You still have to work out a macro that does this.
Using pietzcker's regexp's I have this suggestion for a macro:
PerlReOn
Clipboard 8
Bottom
IfColNumGt 1
Find RegExp "^(\d+,\d+,)(?:"(?:IDX|SCC|CLASS)","[^"]+","[^"]+")(.*)\r\n"
CutAppend
Open "C:\temp\Copy of Vol007-ExcludedFiles_IncludedRecords.txt"
Find RegExp "^(\d+,\d+,)(?:"(?:IDX|SCC|CLASS)","[^"]+","[^"]+")(.*)$"
Replace All "\1"TIF","","ExclusionPlaceHolder.TIF"\2"
