Remove contents of one file from another
Postby cmcfarling » Thu May 08, 2008 11:49 am
Say I have 2 text files where each line is simply a domain name. I need to remove from file1 the contents of file2. Note that file1 is 80000 or so lines long. Is that something that UltraEdit can do or would UltraCompare be needed? In either case is this something that can be accomplished with built in commands or would some scripting be required?
cmcfarling
Re: Remove contents of one file from another
Postby Mofi » Fri May 09, 2008 2:37 am
That can be done with a simple macro. Make sure you have only the 2 files open and file 2 with the lines which should be deleted in file 1 has the focus when you run the macro. The macro is written for DOS files. If you run it on UNIX files without automatical convert of the UNIX line endings to DOS line endings replace all 3 ^p by ^n in the macro.
The macro property Continue if a Find with Replace not found or Continue if search string not found must be checked for this macro.
Bottom
IfColNum 1
TrimTrailingSpaces
Find "^p^p"
Replace All "^p"
IfNotFound
SelectAll
CloseFile NoSave
Bottom
IfColNum 1
IfCharIs "#"
DeleteLine
SelectLine
Find "^s"
Replace All ""
