Insert Text (like a template) without having it typed out
Postby caserichard » Tue Feb 17, 2009 4:32 pm
I'd like to create a macro that will insert text like a template does (i.e. all at once rather than inserting each subsequent character). As it is, my macro is something like this:
"TEXT I WANT
TO HAVE INSERTED
IS HERE"
But should I want to undo this, I'd have to hit undo as many times as there are characters inserted.
To get around this, I could use a template, but I've used my 50 global templates up and I want to assign a keyboard shortcut to it.
I could also make a macro that would paste the text to surround a selection, i.e.:
UltraEditReOn
Find SelectText "^s"
Replace All "^sTEXT I WANT
TO HAVE INSERTED
IS HERE"
But this requires that I select something, even if it's a blank space. Is there anything I can do to get around this? I just want to insert a text/string block cleanly.
Hah. I think I've kind of solved my own question talking through this, but I want to post this should anyone else need something similar:
Key LEFT ARROW
UltraEditReOn
Replace All "TEXT I WANT
TO HAVE INSERTED
IS HERE"
This adds a space, selects it, and replaces it with the text you want. Voila, more room for templates in your Macro library. Still, if there's an even cleaner way, please let me know~!
Thanks for your help,
Rick
caserichard
Re: Insert Text (like a template) without having it typed out
Postby Mofi » Wed Feb 18, 2009 4:51 am
Your final macro is a little bit dangerous. If something is currently selected it will be overwritten with a space. Also your last version needs always 2 undo steps. Here is a much more complicated solution which either uses the current selection or selects something left or right the cursor position depening on the current column before running the replace. If that all fails it inserts a space, selects it and inserts the text with the replace. Only the last one produces 2 undo steps. With the standard settings the last one is needed only on an empty file.
UltraEditReOn
IfSel
Replace "^sTEXT I WANT
TO HAVE INSERTED
IS HERE"
ExitMacro
IfColNum 1
Key RIGHT ARROW
IfSel
Replace "TEXT I WANT
TO HAVE INSERTED
IS HERE^s"
Key LEFT ARROW
ExitMacro
Key LEFT ARROW
IfSel
TO HAVE INSERTED
IS HERE"
ExitMacro
Key LEFT ARROW
Find SelectText " "
TO HAVE INSERTED
IS HERE"
Postby caserichard » Wed Feb 18, 2009 1:09 pm
OOoh, very nice. And such a quick response from the famous Mofi! Thanks very much for your kind reply and efficient solution.
caserichard
