How to insert the date in a specified format with a macro?
Postby AllanB » Thu Mar 12, 2009 9:35 am
new to macros. Love UltraEdit.
What I want to do is at the end of this macro I want to put a string of today's data in this format: _2009-03-12-11-03AM.txt
The macro won't compile due to the last line. It appears I cannot interpret the code sample in the manual correctly.
Any healp would be greatly appreciated.
TIA
Allan
InsertLine
InsertLine
"/* NAME : "
CopyFilePath
InsertLine
"/* PROJECT : xxxx */"
InsertLine
"/* AUTHOR : AllanB */"
InsertLine
"/* LAST MOD : "
TimeDate
InsertLine
InsertLine
InsertLine
InsertLine
[DATE_USER_SYS]'_'yyyy'-'mm'-'dd'-'hh'-'mmtt[DATE_USER_SYS_END]
AllanB
Re: How to insert the date in a specified format with a macro?
Postby Mofi » Thu Mar 12, 2009 10:04 am
You can't use a template definition in a macro. You have to create a template and call this from within the macro. For example I have 2 templates:
Template 0 is named "Date German" and has the template code [DATE_USER]dd'.'MM'.'yyyy[DATE_USER_END]
Template 1 is named "Date International" and has the template code [DATE_USER]yyyy'-'MM'-'dd[DATE_USER_END]
In a macro which is written for updating dates in HTML files I use the macro commands Template 0 and Template 1.
A second variant is to use the macro command TimeDate to insert date and time as defined in the Windows regional and language settings and reformat it with a regular expression search and replace. I don't like this method because it depends on the date and time format defined in the regional and language settings of Windows. So I don't have control how the inserted date and time looks like. But this variant has the advantage that it does not depend on the currently loaded templates.
Postby AllanB » Thu Mar 12, 2009 11:21 am
Thanks for you help
Allan
AllanB
