Count lines in all open files
Postby TheLoon » Thu Mar 03, 2005 7:16 am
Does anyone have a macro that will count the lines in all currently open files?
TheLoon
Re: Count lines in all open files
Postby oracledba » Thu Mar 03, 2005 5:00 pm
An easy way to get your answer is to do a search replace on all open files. Do a non regular expression search for ^p and replace with same ^p.
The upside to doing this is UE gives you feedback on what it replaced.
Example 14 items replaced in 2 files.
The down side of this method is that you have just marked every file as being changed hence when you exit you'll be prompted to save your changes.
oracledba
