BlogTripper wrote:I downloaded the Perl ctag stuff ... how do I use it? and what does it do?
Ctags generates an index (or tag) file of language objects found in source files that allows these items to be quickly and easily located by a text editor or other utility.
BlogTripper wrote:I opened Ctag options and set default tag file to \ctags-5.6\perl.c ... is that correct? the only thing it appeared to do was remove the different colored text and stopped showing my whre the matching { } were what is the original default tag file?
