Textpad $clip replacement in UltraEdit/UEStudio
Postby sebadaza » Thu Sep 21, 2006 8:27 pm
hi all,
1) I have a problem with my tool configuration. I uses a program (tdRunSyntax.exe), that executes syntax spss command. previously I uses textpad and it works well. I change to ultraedit, but I have a problem with the $clip parameter of textpad (selected text in the active document, or the whole document if nothing is selected, is copied to the clipboard before running the tool. this is not a real parameter, in that nothing is substituted in the command line). tdRunSyntax runs well with ultraedit, except for that I have to copy syntax before run tool, every time. Exists a $clip parameter for ultraedit? How I can solve this trouble?
2) other question: How I can create tag of more than one line?
thanks for all!
Seba Daz
sebadaza
Re: Textpad $clip replacement in UltraEdit/UEStudio
Postby Mofi » Fri Sep 22, 2006 8:25 am
1) No, there is no equivalent for $clip in UE. But this is no problem. You can create a macro in a macro file which is set to be automatically loaded when UE is started. The macro contains for example following lines:
IfSel
ToggleBookmark
SelectAll
GotoBookmark
ToggleBookmark
RunTool "case-sensitive name of the user tool"
Assign the hotkey you normally use to run your user tool to the macro.
2) See taglist file!
Postby sebadaza » Sat Sep 23, 2006 12:59 pm
mofi, thanks for the answer, macro works excellent!!!!
thanks again!
Seba Daza
sebadaza
