Ultraedit Passing wrong filename or temp file name.
Postby srparvath » Wed Jul 28, 2004 8:14 am
I succesfully configured Ultraedit to invoke Oracle SQL * Plus to execute PL/SQL files. It was fine for a day and suddently something happend and Ultraedit is passing temp file names to sql plus.
Tool Configuration in UltraEdit:
SQLPLUS.EXE USERNAME/PASSWORD@TNS @%N%E
Output to Listbox.
Now the filenames passed and error is as follows:
unable to open file "PC818A~1.PLS".
My file name is "PCDCRMFDET_Pkg.pls".
Any help is appreciated.
Sam
srparvath
Re: Ultraedit Passing wrong filename or temp file name.
Postby AlGonzalez » Wed Jul 28, 2004 11:09 pm
It isn't a temp file, it is passing the short 8.3 filename.
According to the help you should pass the file using lower case %n%e and enclose it in quotes in case the file name has spaces.
So it should look like this:
SQLPLUS.EXE USERNAME/PASSWORD@TNS @"%n%e"
not sure if the first quote should go in front of the @ or after.
HTH
Al
AlGonzalez
Postby srparvath » Thu Jul 29, 2004 7:52 am
Thanks Al...You are right. It worked with minor change.
SQLPLUS.EXE USERNAME/PASSWORD@TNS "@%n%e".
Remember no spaces between @ and %
Thanks again.
Sam.
srparvath
