How is it possible to integrate Perltidy in the UE IDE, to use Perltidy directly out of the editor?
Has anyone experience with Perltidy and Ultraedit?
Ciao - Jens
jens_g wrote:How is it possible to integrate Perltidy in the UE IDE, to use Perltidy directly out of the editor?
perltidy "%f"
* Run perltidy on the current selection
if (UltraEdit.activeDocument.isSel()) {
var tidyin = "C:\\Temp\\perltidy.txt";
var tidyout = tidyin + '.tdy';
// Hack! Thanks, jorrasdk
// http://www.ultraedit.com/index.php?name=Forums&file=viewtopic&t=4571
var idx = getActiveDocumentIndex();
// Switch to a clipboard that's probably not in use
UltraEdit.selectClipboard(9);
// Save selection to temporary file
UltraEdit.newFile();
UltraEdit.saveAs(tidyin);
// Run perltidy on code from selection
// Tool must exist and be configured to run 'perltidy "%f"'
UltraEdit.runTool("perltidy file");
// Close tempfile
UltraEdit.closeFile(tidyin, 2);
// Get perltidy output
UltraEdit.open(tidyout);
UltraEdit.closeFile(tidyout, 2);
// Replace selection with output of perltidy
UltraEdit.document[idx].paste(); // why doesn't activeDocument work here?
// Restore the clipboard we were probably using before
UltraEdit.selectClipboard(0);
/* Find the tab index of the active document */
for (i = 0; i < UltraEdit.document.length; i++) {
tabindex = i;
break;
return tabindex;
