cvs tools integration
Postby sebab » Tue Dec 07, 2004 10:27 am
Hi all,
Has anybody tried/succeeded integrating UE with cvs client? The best would be with TortoiseCVS ;)
I'd like to able to at least diff, commit and update from UE, on currently edited file.
regards,
Sebastian
sebab
Re: cvs tools integration
Postby toddm » Wed Dec 08, 2004 9:17 am
I created Tools to call Perforce. You should be able to do the same with CVS. For example to open a file for edit my Tool command is p4 edit "%f".
toddm
Postby irotas » Thu Jan 13, 2005 10:09 pm
Hi Sebastian,
I'd also love to see CVS integration in UltraEdit, especially with the UltraCompare integration for diff's.
I agree with you that diff, commit, and update are essential.
Have you had any luck integrating TortoiseCVS ?
Adam
irotas
Postby andreasf » Tue Jan 18, 2005 6:38 am
Hi toddm,
Have you created any Shortcuts to call a Perforce-Submit ? I'am not able to do that :(, because there is no plugin to raise the perforce-edit window.
Have you solved this problem, or any workarounds ??
andreasf
Postby toddm » Tue Jan 18, 2005 2:05 pm
I haven't created a P4 Submit tool. I guess because I usually submit more than one file at a time so I just use the GUI in that case if I'm working in Windows. I created edit, revert, sync, and diff tools. I have diff setup to use a graphical tool called tkdiff and it gets loaded properly so I'm not sure why submit would cause a problem.
toddm
Postby illico » Wed Jan 19, 2005 6:23 am
I use WINCVS and TORTOISE in my Windows2000 OS.
I use UE as file editor
And In the UE tools bar I add severals icon for mys tools, like CVS command...
Check that the cvs.exe is in your path and creates tools like this that works fine:
example : PATH : ... ; D:\Outils\WINCVS~1.3\CVSNT; ...
VIEW STATUS OF SELECTED FILE
Command Line : cvs status -q %N%E
Working directory : %P
check output capture
In advanced parameters, set the icon image file
UPDATE SELECTED FILE
Command Line : cvs update %N%E
COMMIT SELECTED FILE
Command Line : cvs commit -m "no message" %N%E
With adding %modify% to the commit command you can edit the commit message when executing the command.
PS: Check that your CVSROOT path variable is set !
illico
