Search ctags and Bookmark
Postby michaels » Mon Jun 18, 2007 7:12 am
within the normal search I've found the abillity to bookmark my current position before search automatically. But when I search ctags, I didn't get this bookmark. Is the an option I've forgot to switch on?
michaels
Re: Search ctags and Bookmark
Postby Mofi » Mon Jun 18, 2007 9:26 am
No, you have nothing forgotten. Find Symbol is not a normal find. The current position is never bookmarked when you execute Find Symbol and there is no option to enable it. Simply use Search - Back (last position) from menu, toolbar or via hotkey when you want to go back to the initial cursor position before using Find Symbol.
Postby michaels » Mon Jun 18, 2007 10:56 am
thats all I need.
michaels
