Hi ultraeditors --
Im trying to create a very simple user tool that will run a dos "mkdir" command for me. I'd like to use it with a path I have already built and sitting in ultraedit's clipboard 4 ("c:this/that/here/there/yadda")....
...however, I can't quite finger out how to paste or send the clipboard's contents to the user tool immediately after the "mkdir" command. I doubt there is a dos command/shortcut that will "paste" is there?
Any suggestions on how to accomplish this relatively simple task of making a directory? Or if my whole approach is wrong, alternative ways to generate a directory on the fly from UE or the user tool?
Im using v13.20, so Im a bit back on the upgrade curve, if that matters.
tnx much all,
WZ
