Can I configure codepage / encoding for captured output
Postby handyjan » Fri Sep 26, 2008 4:19 am
I am setting up UltraEdit to query a MSSQL 2005 database, using sqlcmd.exe from the tools configuration.
I am able to get the query running, and also I can capture the output to a new file. It seems however, that the output encoding or codepage differs from the one I see, when i fire the command in a DOS box. I need UltraEdits output window to return output, using the same codepage / encoding I use from my system locale (Windows 1252 Danish).
I have tried multiple approaches, like setting the codepage/locale in the advanced menu, but I have had no luck so far.
Can anyone help me with this?
Thank you in advance.
Jan
handyjan
Re: Can I configure codepage / encoding for captured output
Postby jorrasdk » Fri Sep 26, 2008 4:57 am
I have no one time solution to offer, but my workaround to get the encoding fixed whenever I have captured from DOS output into Windows is to use the UE convert:
File - Conversions - OEM to ANSI
(this way I get my captured Danish letters æøåÆØÅ back into readable form)
Postby handyjan » Fri Sep 26, 2008 5:14 am
@jorrasdk
Thanks for the advice, sometimes "the obvious" is a good solution :P
The slightly more persistent solution could perhaps be to record a macro that fires the sqlcmd tool and then makes the conversion. I will look into that.
Thank you!
Jan
handyjan
