Convert open files to project / create new project from open files?
Postby lpollis » Wed Feb 01, 2006 2:37 am
If, after opening several files in UltraEdit (or UEStudio, for that matter), I want to create a project, or save my workspace with those files, how can I do this? :?:
Lp
lpollis
Re: Convert open files to project / create new project from open files?
Postby Mofi » Wed Feb 01, 2006 8:00 am
If this is set in the INI file
[Settings]
Always Close Files=0
then you can simply click on New Project/Workspace. After entering the project file name you will be asked to close all open files or not. Select No and then in the next dialog click on button +All Open Files.
The setting can be changed also via Advanced - Configuration - File Handling - Miscellaneous - Close all files when opening or switching projects.
Postby Jpsy » Tue Apr 25, 2006 8:35 am
Hi Mofi,
this info solved my problem.
THX for your help.
Jpsy
Return to Projects/Workspace
