Showing differences in files while in Folder Mode?
Two- and three-way folder compare and merge issues.
Postby sew4412 » Wed May 23, 2007 10:24 pm
Is there no way to show the text differences between two files when Folder Mode? Basically what Im trying to do is look at the differences between two folders, scroll down to the line that either says "First Newer" or "Second Newer" and invoke something like Text Mode on the two files by either right clicking or some means.
Is this possible?
thanks in advance
Stan
Update--
I did see that you could invoke UE from tool bar and then do a compare files. But this is way too tedious when I only want to view the differences.
sew4412
Re: Showing differences in files while in Folder Mode?
Postby Mofi » Thu May 24, 2007 6:45 am
Simply double click with the left mouse button on the line with the files you want to compare in text mode from within folder mode and a new instance of UltraCompare will open with the 2 files compared in binary or text mode depending on the file type you can see in the folder compare window. Press CTRL+T to switch to text compare mode if the files are text files, but compared in binary mode.
Alternatively you can compare the 2 files also as described in the last paragraph on the help page Folder Compare.
By the way: I use UltraCompare Professional v5.00.
Postby sew4412 » Thu May 24, 2007 11:39 pm
Thanks Mofi, I must be braindead I didnt even try doubleclick.
sew4412
Return to Folder Compare and Merge
