Getting Edit | Comment Add to use block comments
Postby sjibben63 » Tue Mar 29, 2005 6:44 pm
I do a lot of HTML/ColdFusion work and those languages tend to only have block comments.
Is there a way to set up UE so that it will use block comments instead of single line comments for the Edit | Comment Add feature? This feature is always greyed out (disabled). I think that is because there isn't a line comment defined in my wordfile.
I'm working on converting from MultiEdit 9.x to UE and ME could put a block comment on each line or as a block depending on how you highlighted the code to be commented. Example:
<!--- single block
comment for lots
of lines
of code when highlighed in a stream. --->
or
<!--- many block --->
<!--- comments for lots --->
<!--- of lines --->
<!--- of code when highlighted as full lines. --->
I also had hot keys for quickly commenting/uncommenting code. That should be easy to set up if I can get UE to use block comments...
sj
sjibben63
Re: Getting Edit | Comment Add to use block comments
Postby Mofi » Wed Mar 30, 2005 1:51 am
This can be solved with macros, which are assigned to hotkeys and automatically loaded (not executed) at start of UE. The macros modify only when something is selected and the file extension is .html or .htm.
Macro for adding "line" comments:
IfSel
IfExtIs "html"
Find RegExp "%^(*^)$"
Replace All SelectText "<!-- ^1 -->"
IfExtIs "htm"
Macro for removing "line" comments:
IfSel
IfExtIs "html"
Find RegExp "%<!-- ^(*^) -->$"
Replace All SelectText "^1"
IfExtIs "htm"
