UltraEdit starts slower after installing WinXP SP2
Postby vonip » Tue Aug 17, 2004 5:17 pm
UltraEdit starts slower (ca 2.2s vs 0.9s) after installing WinXP SP2.
Please, where is the problem ?
vonip
Re: UltraEdit starts slower after installing WinXP SP2
Postby drandazz » Fri Aug 27, 2004 7:31 am
I also have the same issue. Win2k with Sp2, SP3 and now SP4 has made no difference. I am now using UltraEdit v10.20c with the same results.
drandazz
Postby mrainey56 » Fri Aug 27, 2004 8:53 am
This is from the Help file. I think it's solved the problem for some people.
Advanced > Configuration
General Tab
Scroll to the bottom
Load/Restore printer settings
UltraEdit tries to communicate with the printer driver when it loads and shuts down (to preserve settings). If a network printer is specified as the default printer and not available this may cause a delay on startup while UltraEdit tries to find the printer on the network. If this option is not selected then UltraEdit does not communicate with the printer.
mrainey56
Postby billmeier » Fri Aug 27, 2004 2:58 pm
If you aren't using a network printer, this isn't your problem. The trouble is in SP2 Windows seems to be very anal about files in the \Windows directory, which where by default, UEDIT32.INI is.
I'm not sure how Ultraedit deals with this file during startup, but I think it puts Windows into its "is it OK to play with this file in \Windows? mode".
Ultraedit has a setting to store the profile into the registry rather than in UEDIT32.INI - Under the advanced features, it says add
Use Registry = 1
Put this in your INI file just after [Settings]. Restart UE and things should go MUCH faster! A down side of this is that you loose all your custom settings... but if you only have a few, its worth putting them back in to save the startup time.
Let me know if this works for you!
billmeier
