Fast sync scroll gets out of alignment?
Postby epack » Mon Oct 01, 2012 1:03 pm
UE Version 18.20.0.1017 but I've noticed this in earlier versions too.
I frequently view two similar files tiled vertically in the UE window, then turn synchronized scrolling on so that I can quickly see fairly obvious differences between the two files. As long as I scroll relatively slowly, they stay nicely in sync, but I've noticed that if I speed up the scrolling beyond a certain (random) speed, one of the panes, typically but not always the right hand one, quickly "jumps" ahead by half a dozen lines or so, even tho they have the same number of lines.
Anyone else notice this or have a fix? (and yes, i do have UCompare too, but this method allows me to make changes to the files on the fly :)
TIA
elaine
Ivy, VA
epack
