schwoortz wrote:The Snippet functionality that I mean includes code-snippets, that can be "wrapped around" marked text.
Mofi wrote:schwoortz wrote:The Snippet functionality that I mean includes code-snippets, that can be "wrapped around" marked text.
In UltraEdit this can be doneIf they are correct defined, they insert the text around the currently selected text, if there is a selection. The cursor position after inserting the "snippet" can be also controlled.
- with Templates - see Advanced - Display/Modify Templates; press F1 when dialog is open to get the help and use forum search for more infos.
- with Tags - see Views - Views/Lists - Tag List; press right mouse button in the list window and select Modify Tags to create your own tags; help can be found in UltraEdit help and with the forum search.
- with HTML Toolbar - see Advanced - Configuration - Toolbars / Menus - HTML Toolbar; help can be found in UltraEdit help and with the forum search.
