How do I remove UltraEdit from Windows Explorer drop-down menu?
Postby volitics » Fri Nov 10, 2006 3:56 pm
Hello;
When I click on a file in the Windows Explorer the drop-down menu says open with UltraEdit.
In the Configuration-->File Associations panel I have got .txt and .php files associated with UltraEdit. Those are the only two file types that I have associated with UltraEdit.
When I click on an Html page it still says open with UltraEdit. Html pages are not set to be associated with UltraEdit in the Configuration-->File Associations panel.
Can somebody tell me how to remove UltraEdit from the Windows Explorer drop down menu?
volitics
Re: How do I remove UltraEdit from Windows Explorer drop-down menu?
Postby Mofi » Fri Nov 10, 2006 5:01 pm
If you have specified during installation or since v12.20 in the File Associations config dialog that UltraEdit should be in the context menu for all files (known and unknown - all = *) than it is in the context menu for all files.
If it is only in the context menu of HTML files open Windows Explorer - Tools - Folder Options - File Types - HTML Document (or something similar) and set there the file associations you want for HTML files.
I'm really wondering how my Windows users don't know where to specify/modify the file associations.
Postby volitics » Fri Nov 10, 2006 9:18 pm
It seems to be in the context menu for all files. It's also in the context menu for jpeg files, windows media player files, and bitmaps.
You're saying that I need to uninstall and then re-install?
volitics
Postby Mofi » Sat Nov 11, 2006 1:44 pm
If you have UltraEdit v12.20 or higher you can remove the shell integration for all files in the config dialog Configuration - File Associations.
If you have a previous version you can run the UltraEdit setup and use the third option to remove the shell integration.
Or maybe more easily you copy following 5 green lines to a new ASCII text file, save it for example with name no_ue_context_menu.reg and double click on this registry file to import it with Regedit into your registry which in this case deletes 2 registry keys. You need administrator privileges for this task.
REGEDIT4
[-HKEY_LOCAL_MACHINE\Software\Classes\*\shellex\ContextMenuHandlers\UltraEdit-32]
[-HKEY_LOCAL_MACHINE\Software\Classes\CLSID\{b5eedee0-c06e-11cf-8c56-444553540000}]
For more details about the shell integration of UltraEdit see right click to "open in UltraEdit".
Postby volitics » Sat Nov 11, 2006 3:16 pm
I re-installed the program and chose option three. It worked great. Thanks.
volitics
