Is there a way to make the Ctrl+Tab and Shift+Ctrl+Tab cycle through the documents in the order they're in on the tabs rather than how they're stacked in Z order? I maximize the editor windows inside UE and I really have no idea what Z order they get into after I switch back and forth between a few files. I'd love it if ctrl+tab would just cycle through the tabs, left to right.
I know I can sort the tabs by Z order, but I'd rather be able to order the tabs the way I want them, then have that order stick.
