Mofi wrote:When you select a block in column mode and hit for example space, all characters of the selected block are replaced by the space character.
I have spent all week on this quest , tried just about everthing out there. I really like UltraEdit's interface - it's the best of them all. I'm going to continue my production work with TSE Pro for now, but will also continue to work at configuring UltraEdit and learn more about it. Thanks again to forum members for your help.
Mofi wrote:I know TSE very well. We worked with it for many years til Windows 95/98 get default OS on all of our PCs. We also tried the first "windows" version of TSE, but that was a really bad one because of DOS engine with Windows GUI - horrible.
Clayton wrote:This is not a casual request. I use this functionality constantly in my programming and most other editors have this or something close to it. What I have described here is what TSE Pro has and I've gotten spoiled.
Clayton wrote:I make heavy use of column blocks. Having to turn on the column mode, then use the Shift key, then copy it to a clipboard, then not be able to see it and guage where it will fit - it's like loading an antique gun one bullet at a time, then shooting in the dark, and then turning on the light to see if you hit the target...I'm used to a machine gun in broad daylight.
