Base 64 encoding and decoding of binary data in a text file?
Postby reisner » Wed Jan 20, 2010 4:58 pm
Anyone know of a step-by-step to correctly using the new (in 15.20) "Base 64 encoding and decoding" feature?
I have been awaiting this feature; and have been using Notepad++ when I've needed it.
However, I cannot seem to figure out how it works in UE.
Using the working excerpt, below, in Notepad++ I highlight all the lines starting at "UE" and ending at "CQAAAAA=" and copy&paste just those lines into a new edit window; highlight those lines in the new edit window ("Select All"), and then select Base64 Decode. I end up with GetTableFields.zip "displayed" in that new edit window (looks like garbage, of course) and I "Save As..." "GetTableFields.zip" and I get a working GetTableFields.zip on disk that I can unzip or whatever.
The same steps do not produce a "working" GetTableFields.zip in UE; and I cannot figure out a sequence of steps that do work.
Anyone?
Thanks!
-----------------4141397533
Content-Type: application/ZIP;
name="GetTableFields.zip"
Content-Transfer-Encoding: base64
Content-Disposition: inline;
filename="GetTableFields.zip"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-----------------4141397533--
reisner
Re: Base 64 encoding and decoding of binary data in a text file?
Postby danne » Wed Jan 20, 2010 6:22 pm
I haven't tried the feature, but do you f.ex have "trim trailing spaces on save" enabled?
If I were you I'd diff the files created and see what differences there are. It might lead you to what is wrong.
danne
Postby reisner » Wed Jan 20, 2010 7:52 pm
Good thoughts; but no dice yet.
I checked various settings in UE; and "Trim Trailing Spaces on Save" was Off (as it should be for this I suppose).
But, "Allow low ASCII values t be entered" was off. I changed it to on.
"Allow editing of text files with HEX 00's without converting them to spaces" was also off. I changed it to on.
But the same thing happens.
Basically, UE only decodes the first 5 bytes. When I look closer at those bytes and the "working" zip in hex mode; I see that the sixth, seventh and eighth bytes happen to be 00 (null) in the working zip produced by Notepad++.
I guess that despite my changing UE options that specify hows to handle 00's, UE's Base64 Decode is for some reason stopping the decode when it decodes a null value.
There may be other options I still need to set correctly. But there is no help on the new Base64 Decoding that I can find, that might explain what I need to do.
Perhaps tomorrow, if someone hasn't chimed in that knows what to do, I will email UE tech support about this.
Thanks!
reisner
Re: Base64 encoding and decoding of binary data in a text file?
Postby Mofi » Thu Jan 21, 2010 2:15 am
In your case you would need a working base64 decoding in hex edit mode. I think IDM has implemented the feature only for base64 encoding/decoding for text content and not for binary content. It is possible to execute command Decode Base64 also in hex edit mode, but then UltraEdit tries to decode the displayed ASCII strings instead of the real selected bytes of the file.
I suggest to write an enhancement request email to IDM support asking for Decode Base64 and Encode Base64 working on the selected bytes of the file instead of the displayed string when hex edit mode is active for the current file to be able to encode/decode also binary data.
Postby reisner » Thu Jan 21, 2010 8:58 am
Perhaps that is correct.
Too bad there doesn't seem to be any real docs on exactly how it does work; forcing guesses to be made.
I will email them today; but since I don't know positively that that is why it doesn't work I will simply supply my sample and ask them how to make it work. Then they can tell me it won't work because it is a binary decode. At that point I can feel comfortable to suggest it should work in any case (as it does in Notepad++).
Thanks for your input!
reisner
Postby reisner » Wed Feb 10, 2010 11:08 pm
I thought I'd post a followup on this issue.
I had an email exchange with IDM about this issue; and below is the most recent reply.
So it is a bug, but it is going to be fixed.
> From: IDM Computer Solutions <...>
> To: <...>
> Sent: Thu, February 4, 2010 8:21:08 AM
> Subject: Re: Base64 Decode - how to make it work?
> Hello Ron,
> Thanks for your response. This issue has been assigned
> for a fix, however the developer who is working on this
> will be out of the office for a few days. I will make sure
> you're notified as soon as a fix is available. I apologize
> for the delay.
> Thanks,
reisner
Postby reisner » Thu Mar 11, 2010 11:15 pm
I am pleased to report that the Base64 decoding problem I reported in this thread, has been fixed! Today I was sent a link to a 16.00.0.1030 version, and requested to test the fix in it. I have reported back to them that the problem is fixed. Hopefully that update will be released soon.
Hooray!
Ron
reisner
