Menu Window locks up, fixed with UE v16.10.0.1035
Postby epack » Sat May 29, 2010 6:20 pm
Just upgraded to v16.10.0.1021 uneventfully, but upon trying to use it, most everything works but oddly, the Windows menu item at the very top does NOT work. If I click on any of the others, the menu opens normally, but the Window one will not.
Windows XP SP3 environment.
Anyone else seeing this? Better, is there a fix? I've tried rebooting, but didn't help. I can reinstall it, but only if I have to, I guess.
Even odder. I discovered that if there is no file editing window open, the Window drop works fine. As soon as I either open a file or simply click on New file, it freezes everything and I have to abort out of UE.
Weird...
TIA
elaine
epack
Re: Menu Window locks up, fixed with UE v16.10.0.1035
Postby RoyFX7 » Mon May 31, 2010 12:19 am
If I set the entry
"OldMenuWindowList" to 0
(Uedit32.ini) the "windows" menu opens normally.
Change it to 1 -> UE freezes.
Before version 16.10.0.1021 it works always.
In my opinion, it's a little bug in the new version ...
RoyFX7
Postby epack » Mon May 31, 2010 5:42 am
Excellent!! That worked!! The full solution in the configuration turned out to be here:
Application Layout - Advanced
Clear check box for Old-Style Window List
Thanks so much RoyFX7!!
elaine
epack
Postby Mofi » Tue Jun 01, 2010 12:47 am
Hm, I'm also using currently UE v16.10.0.1021 on Windows XP x86 with SP3, have 19 files open and configuration setting Old-style window list is also checked, but I don't see any problem with menu Window on the main menu. Perhaps another setting is also important. I'm using non dockable open file tabs with type Single line - scrollable.
Postby Mofi » Fri Jun 25, 2010 1:12 am
Fixed hang when clicking Window list when old-style window list and dockable file tabs are both enabled
According to the change list of hotfix version 16.10.0.1035 this issue (which I could not reproduce) should be fixed now in UltraEdit v16.10.0.1035. Could someone having this problem confirm here that the problem is solved in UE v16.10.0.1035 with a post? Thanks.
Postby RoyFX7 » Tue Jun 29, 2010 5:02 pm
Yes, I can confirm it.
This problem is solved in UE v16.10.0.1035.
RoyFX7
