Search Drop Down is missing
Postby Kelly » Tue Nov 30, 2004 2:57 pm
I have searched the forum and cannot find this topic....
I used to have a drop-down search box in my toolbar. But, after a re-install, I have lost this functionality. Does anyone know how to get it back?
Thx
Kelly
Re: Search Drop Down is missing
Postby mrainey56 » Tue Nov 30, 2004 4:35 pm
Look at the Help file under "Configure Toolbar"
Then, when you right-click on an empty spot in the toolbar and select "Customize", the control you want is under "Custom Buttons" in the dialog.
mrainey56
Postby Kelly » Tue Nov 30, 2004 5:02 pm
I am using an older version of UltraEdit. I have gone through all of the controls and the drop down box is not one of them. I re-installed the same version as I had previously. I cannot even right click on the toolbar. I do not have that option.
Kelly
Postby Mofi » Wed Dec 01, 2004 4:00 am
You have the old style toolbar. This toolbar has to be configured at Advanced - Configuration - Toolbar.
From the feature list insert at least one of the 2 find features Find Text or Find Next.
Press OK and close UltraEdit. Start UltraEdit again and the drop down list is left the find icon.
Postby Kelly » Wed Dec 01, 2004 9:10 am
It must be a bug. Only the icons show up. No dropdown.
Thanks for your suggestions.
Kelly
Postby Mofi » Wed Dec 01, 2004 11:24 am
I just remembered, that you also need an ini-setting to enable the find drop down list in the old style toolbar. Check your ini-file for
[Settings]
TB FindString=1
