Maximizing windows
Maximizing windows
Postby ArnyEinstein » Thu Sep 13, 2007 7:19 pm
Hi
Is there a keyboard command that maximizes a window (of course, I can click on the symbol next to the close symbol), but I like to work with my keyboard. I tried recording a macro but that did not work.
ArnyEinstein
Re: Maximizing windows
Postby Mofi » Fri Sep 14, 2007 2:23 pm
The document window or the application window?
The MS page Keyboard shortcuts for Windows contains some general Windows hotkeys.
Interesting for you will be
MS wrote:ALT+SPACE: Displays the main window's System menu (from the System menu, you can restore, move, resize, minimize, maximize, or close the window)
ALT+- (ALT+hyphen): Displays the Multiple Document Interface (MDI) child window's System menu (from the MDI child window's System menu, you can restore, move, resize, minimize, maximize, or close the child window)
On a German Windows the next key after Alt+Space or Alt+- which must be pressed is the x to Maximize the application or document window.
