I may be real late on the subject. I just found the answer to fix the same problem I was facing. Thought I would share it with you all.
It's actually quite simple.
Goto "Control Panel", "Regional and Language Options". Click on the 3rd tab - "
Advanced". The top box reads: "
Language for non-Unicode programs". Choose the language you will be using for those that shows gibberish in your UE editor. Click on OK twice. The dialog box will ask if you want to
restart the computer for the change to be effective. Choose YES to restart your computer and make immediate change.
That's all, folks.
