New Color Scheme (Tango Dark)
Re: New Color Scheme (Tango Dark)
Postby rhapdog » Wed May 05, 2010 8:39 am
In case anyone is still monitoring this thread and wants to upgrade UE from a version prior to version 15, but have heard of the difficulty in changing over to the new word file syntax coloring, then check the thread Color Scheme Management Tool.
This new utility, which has at long last been released, can handle the following for you:
* Export wordfile colors to one or multiple wordfiles.
* Clear all color information from one or multiple wordfiles.
* Split a multi-language wordfile into separate wordfiles.
These 3 functions effectively replace all the macros that were written to accomplish this, but it takes all the guess work and removes the difficulty level.
In addition, you will be able more easily manage your colors:
* Import/Export from/to UltraEdit/UEStudio for both Color Schemes and Wordfile Colors.
* Create/Load/Save Color Schemes in INI file format to make it easier for human reading and for trading color schemes with others.
Postby bill » Thu Mar 17, 2011 3:57 am
It appears that IDM used the Tango Dark color scheme when advertising UE v17.00. Does this mean we will have a quick and easy way of using this color scheme?
UltraEdit advertisement showing Tango Dark color scheme
bill
Postby Nologic » Sat Mar 19, 2011 5:58 pm
Hi Bill,
It's not Tango..but it's certainly a lot like it. :)
I have no idea if what they show will be the default or an option...but ideally they have made it easier to add schemes to UE.
I guess we'll just have to wait and see.
You may want to try out rhapdog little app...as it will apply Tango Dark to UE.
*Update*
Since UE is allowing for more color's, I figured I should list all the available colors for Tango Dark.
Butter 1       5237244
Butter 2       54509
Butter 3       41156
Chameleon 1    3465866
Chameleon 2    1495667
Chameleon 3    432718
Orange 1       4108284
Orange 2       31221
Orange 3       23758
Sky Blue 1     13606770
Sky Blue 2     10773812
Sky Blue 3     8866336
Plum 1         11042733
Plum 2         8081525
Plum 3         6698332
Chocolate 1    7256553
Chocolate 2    1146305
Chocolate 3    153999
Scarlet Red 1  2697711
Scarlet Red 2  204
Scarlet Red 3  164
Aluminium 1    15527662
Aluminium 2    13621203
Aluminium 3    11976122
Aluminium 4    8751752
Aluminium 5    5461845
Aluminium 6    3552302
Aluminium 7    4869449
Aluminium 8    1776151
Aluminium 9    2631458
Nologic
Previous
