Q: Showing wrap margins
Postby grkuntzmd » Tue Sep 16, 2008 7:11 am
Is there any way to show the current wrap margin in the editor as a vertical line?
grkuntzmd
Re: Q: Showing wrap margins
Postby jorrasdk » Tue Sep 16, 2008 9:30 am
Well sort of. But you have to set a column marker yourself. In UE14 set a column marker at your column of choice using View - Set/Show column Markers....
If you use different wrap margins depending on extention (Advance - Configuration - Editor - Word wrap/Tab settings), you have to switch column marker yourself.
Postby grkuntzmd » Tue Sep 16, 2008 9:48 am
That works for me!
grkuntzmd
