Version 3.0 is averaging about 10 downloads per day. Not bad for such a highly specialized, niche tool.
It all started because I wanted features to make doing certain things in UE easier, and feature requests just weren't being fulfilled the way I wanted. (Like colored theme management.)
There were other things on my list I wanted to be able to do, and now that I have finally finished the previous work on this project, it is time to move on to 4.0, and add more goodies. 4.0, for the most part, will add features that move away from wordfiles and color management.
There will be a few new wordfile features, such as adding in the rest of wordfile editing, such as delimiter editing, fold strings, indent strings, function strings, and also color group management, but that will be as far as the program goes other than the periodic updates to keep up with "new color" options added to future versions of UE and UES.
From here, I plan to get into better management of the history UltraEdit keeps in the INI file. Things like Recent Files, Recent Projects, LCI tracking, saved hidden lines, bookmarks, compare history, search/replace history, etc. Right now, if you clear the history in UE, it clears everything. But what if you want to clear recent files, but not clear your bookmarks? Or clear Search and replace history without clearing recent files or your last used DOS commands?
I have set up new tabs to handle UE History, Tag Lists, and Templates.
- UEHistory.png (10.73 KiB) Viewed 1660 times
Notice that you can decide exactly what you want to have cleared? You can even use the clear buttons to clear one item at a time.
I realize that UE already has what we need to enter/edit Tag Lists and Templates, however, there are, to me, a couple of important features missing here. There is no ability to "import" tag groups from other tag list files and automatically insert them into the current file. That means we have to manually paste them together by hand, and renumber them. It's a real pain. So I plan to make "import and export" to and from tag list files, along with the other tag list functionality.
The same things will be true for templates. I propose that we be able to import one or more text files automatically as templates. This will make it easier for people who have stored file snippets to quickly convert them to templates without having to load them and copy/paste into the template box one at a time. If you have hundreds or thousands like I did, it can be a real pain.
This post is just a bit of an update to let you know what I have in mind for version 4.0. These ideas are why I decided to rename the program from UE Color Management to UE Companion, because, looking down the road, I knew it would have to change.
I don't yet have a timeline on when 4.0 will come out. I have already completed the coding for the clearing of the History, but there is much work to do on Tag Lists, Templates, and the remaining word file tools. Don't expect it before the end of the year, but it will be worth the wait. It you want to test new goodies as they become available, you're welcome to send me an email to my support email address in the about box of the program, and I will set you up for access to betas as they become available.
