Context Help (PHP, for example)
Postby MBaas » Mon Aug 22, 2005 6:41 am
I would like to use the extended CHM-Doc for PHP as helpfile for context-sensitive help when editing .PHP-Files. Has anyone fiddled out how to do this?
Michael
MBaas
Re: Context Help (PHP, for example)
Postby MBaas » Thu Aug 25, 2005 2:21 pm
Aaarg - <blush>. Well, that was too easy, after adding the CHM-File using "Add Help Files" it just worked! :)
I was confused by some complicated instructions on the PHP-site (referring to UE - but I thought that hadn't been changed...)
MBaas
