Post Build Events
Post Build Events
Postby thefuzzer » Mon Jan 19, 2009 11:41 am
Are post-build events supported by UEStudio? I'm looking for something similar to the VisualStudio post-build events. I'm trying to redirect the output file to a different directory, and I'm assuming there's an integrated method of doing this.
thefuzzer
Re: Post Build Events
Postby Mofi » Mon Jan 19, 2009 12:03 pm
Yes, because you can modify the configuration file. Click on Build - Select Compiler, after selecting the correct compiler click on button Edit Configuration and click immediately on button Make Configuration Locale. Scroll down to section [Build] and add additional commands Cmdx=. Of course you can also modify the parameters for the linker so it creates the file directly in the directory you want.
I can't help you more detailed because I don't know which configuration you use. The configuration files vary a lot from compiler to compiler.
Postby thefuzzer » Mon Jan 19, 2009 6:58 pm
Thank you.
thefuzzer
Return to Build / Compile / Debug
