Assign Return value of -qc to Environment Variable
Two- and three-way text compare and merge issues.
Postby zman » Fri Jan 26, 2007 2:48 pm
I am calling:
uc -qc file1.f file2.f
from a command line.
I am returned "SAME" to the command window.
I would like to assign the return value (in this case "SAME") to an environment variable.
set return=uc -qc file1.f file1.f
does not work.
I cannot figure out how.
I do 8 file compares regularly.
Rather then looping through all 8 if only 1 is different, I would like to do a quick compare and only do a text compare if the files are different.
Any help is greatly appreciated.
zman
Re: Assign Return value of -qc to Environment Variable
Postby mwb1100 » Fri Jan 26, 2007 4:59 pm
Windows makes the return code of a program accessible in batch files 2 ways:
1) the ERRORLEVEL environment variable (this may be only in Win2000 and later)
2) the "if ERRORLEVEL ..." command (ever since DOS)
So you can probably do what you want with:
set return=%ERRORLEVEL%
mwb1100
Return to Text Compare and Merge
