Find long file names
Postby gary_johnson_53 » Mon Sep 26, 2011 4:36 pm
Problem: When you save web pages or favorites, you can inadvertently get files that are longer than MAX_PATH.
Objective: find files that are longer than 255 characters
Step 1) get a list of all files dir c:\ /s /b > files.txt
Step 2) Wanted, a script to possibly select all lines longer than MAX_PATH (255) from a file
Don't think this sort of thing will work well when the file is 150,000 lines long
var lineTerminator = "\r\n";
var str = UltraEdit.activeDocument.selection;
var resultArr = new Array();
resultArr = str.split(lineTerminator);
IS this the way you would parse the file, line by line, put this in a loop
UltraEdit.activeDocument.gotoLine(1,0);
selectLine
get line length
if line length > 255 write to ouptut window?
gary_johnson_53
Re: Find long file names
Postby Mofi » Tue Sep 27, 2011 12:24 am
Getting the list of files can be also done with UltraEdit from within a script. Here is the script you need. Please read the comments at top of the script.
// Insert here the code of function GetListOfFiles() downloaded
// from http://www.ultraedit.com/files/scripts/GetListOfFiles.js
// Paste only the code of the function without the code for demonstration
// below the function. If not using English UltraEdit, you have to adapt
// the values of the 2 string variables sSummaryInfo and sResultsDocTitle
// at top of function GetListOfFiles().
if (GetListOfFiles(0,"C:\\","*.*",true)) {
   var asFileNames = UltraEdit.activeDocument.selection.split("\r\n");
   if (UltraEdit.outputWindow.visible == false) {
   var nCount = 0;
   for (var nIndex = 0; nIndex < asFileNames.length; nIndex++) {
      if (asFileNames[nIndex].length > 255) {
         UltraEdit.outputWindow.write(asFileNames[nIndex]);
         nCount++;
   UltraEdit.outputWindow.write("");
   UltraEdit.outputWindow.write(nCount.toString() + " file names longer than 255 characters found.");
Postby gary_johnson_53 » Tue Sep 27, 2011 9:35 am
Thanks for showing me the way!
My current expertise is in DHTML, DOM, HTML, javascript etc. If you have an issue with that kind of web stuff, please do not hesitate to ask.
I am continually surprised when
works on files with over 150,000 lines!
gary_johnson_53
Postby Mofi » Tue Sep 27, 2011 11:52 am
gary_johnson_53 wrote:I am continually surprised when ... works on files with over 150,000 lines!
As long as there is enough free memory on your computer to hold all the strings in memory, there is no problem.
I have just thought that when all the files names are stored already in a file, why not simply delete all lines with less than 256 characters to get the list of files with names longer than 255 characters.
Based on the Perl regular expression posted by pietzcker at How to delete all lines not containing specific word or string or expression? the search string required for this job is ^(?!.{256}).*$\r\n and the replace string is simply an empty string.
Postby gary_johnson_53 » Tue Sep 27, 2011 1:10 pm
Thanks, This stuff is like magic.
gary_johnson_53
