Sorting numbers within a line on all lines of a file
Postby Gradius » Thu Feb 02, 2012 6:03 pm
I'm having a hard time trying to perform simple sorting on Ultraedit.
The file is 100% ASCII, but I'm trying to sort some numbers on it, here is a sample:
01 02 03 04 06 17 19 28 33 43 47 53 54 69 71 78 84 86 89 97 27 28 42 44 53 54 57 59 61 63 65 74 78 79 80 83 86 87 95 96
01 02 03 04 09 10 15 23 25 28 34 41 48 54 72 76 86 87 93 00 26 27 39 42 45 50 54 55 63 67 73 78 79 87 90 91 95 96 99 00
01 02 03 04 10 21 23 29 33 43 49 50 51 60 66 70 74 77 78 80 24 26 38 42 48 49 51 52 54 60 62 63 66 74 82 85 86 87 92 99
01 02 03 04 10 23 29 38 50 51 54 59 60 61 71 72 74 83 90 91 23 30 31 34 35 43 45 46 48 49 53 55 68 75 83 85 88 95 96 99
01 02 03 05 12 16 19 20 27 30 33 39 49 51 59 68 74 80 82 83 23 24 31 39 40 41 46 50 52 56 57 59 64 77 83 84 85 90 91 98
01 02 03 06 07 09 13 23 26 29 34 43 55 60 66 68 81 86 87 97 22 37 43 44 48 54 55 61 67 68 72 79 84 87 91 93 97 98 99 00
01 02 03 06 08 10 12 13 27 36 39 43 45 49 65 72 73 74 87 90 22 31 40 42 44 48 58 61 62 65 68 71 74 77 78 81 83 84 95 96
01 02 03 06 12 21 31 35 46 47 48 50 51 52 59 64 69 71 89 90 22 23 30 31 34 36 48 50 54 56 57 59 61 64 67 80 95 97 98 00
01 02 03 08 14 23 29 33 34 38 43 44 49 52 55 62 65 71 74 94 21 29 31 37 40 44 45 50 55 61 62 79 80 81 83 85 86 88 95 97
01 02 03 10 24 27 32 52 53 62 70 72 78 79 80 87 91 94 97 98 21 26 29 34 37 50 53 56 58 60 67 68 72 77 79 81 83 92 99 00
As you can see the first line needs to become as:
01 02 03 04 06 17 19 27 28 33 42 43 44 47 53 54 57 59 61 63 65 69 71 74 78 79 80 83 84 86 87 89 95 96 97
However, there are some replicated numbers and they need to be deleted as well. On the above example they were: 28 53 54 78 86
How can I do that?
Fernando
Gradius
Re: Sorting numbers within a line on all lines of a file
Postby Mofi » Fri Feb 03, 2012 3:22 am
That task requires an UltraEdit script and here it is.
   UltraEdit.columnModeOff();
   // Select all and load the file contents into an array of lines.
      var asLines = UltraEdit.activeDocument.selection.split("\r\n");
      // Sort the space separated numbers within every line.
      for (var nLineNum = 0; nLineNum < asLines.length; nLineNum++)
         if (!asLines[nLineNum].length) continue;  // Ignore empty lines.
         // Split the line up into an array of number strings.
         var asNumbers = asLines[nLineNum].split(" ");
         // Run a simple string sort based on ASCII table.
         asNumbers.sort();
         // Remove duplicate numbers.
         var nNumberIndex = 0;
         while (nNumberIndex < (asNumbers.length -1))
            // Is current number string equal next number string in sorted array?
            if (asNumbers[nNumberIndex] == asNumbers[nNumberIndex+1])
               asNumbers.splice(nNumberIndex+1,1);  // Yes, remove next string.
            else
               nNumberIndex++;  // No, continue with next number string.
         // Rebuild the line with the sorted numbers with duplicates removed.
         asLines[nLineNum] = asNumbers.join(" ");
      // Replace the still existing selection by resorted lines.
      UltraEdit.activeDocument.write(asLines.join("\r\n"));
Postby Gradius » Fri Feb 03, 2012 11:16 am
It works! You da man! Thanks a lot!
Gradius
Postby Gradius » Sat Feb 11, 2012 1:08 pm
Hi Mofi,
Really sorry to bother you again.
Right now I need another little script capable to count the total of odd & even per line, putting the result at the end as "O:n1 E:n2" (in that same line).
Example:
01 02 03 06 07 09 13 23 26 29 34 43 55 60 66 68 81 86 87 97 22 37 43 44 48 54 55 61 67 68 72 79 84 87 91 93 97 98 99 00 (O:23 E:17)
Of course the example above have the numbers in out of order, but I'll do them in order. Keep in mind 00 should remain as 00 at the end of line if present, but since is just counting I don't believe it would change anything.
Thanks!
Gradius
Postby Mofi » Tue Feb 14, 2012 1:15 am
That was an easy job. Here is the script.
      // Count the even and odd numbers in the lines with space separated numbers.
         var nOddCnt = 0;
         var nEvenCnt = 0;
         // Count the even and odd numbers.
         for (var nNumberIndex = 0; nNumberIndex < asNumbers.length; nNumberIndex++)
            // The decimal numbers as strings must be converted to integers.
            var nValue = parseInt(asNumbers[nNumberIndex],10);
            if ((nValue % 2) == 0) nEvenCnt++;
            else nOddCnt++;
         // Append the result as string to every not empty line. The two integer
         // values are automatically converted here to strings by Javascript core.
         asLines[nLineNum]+= " (O:" + nOddCnt + " E:" + nEvenCnt + ")";
      // Replace the selection by the lines with the even and odd counts.
Postby Gradius » Sat Feb 18, 2012 8:20 pm
Thanks it works!
Gradius
Postby Gradius » Fri Mar 29, 2013 12:48 am
I need a new filter, where it perform sort first and then removes duplicated numbers, line by line. Number range is from 01 to 00 (where 00 is like 100).
Example:
03 07 11 13 14 16 15 19 23 25 26 28 27 25 31 35 37 38 35 40 39 43 47 49 50 52 51 55 59 61 62 64 63 67 71 73 74 76 75 79 83 85 86 88 87 91 95 97
Result in:
03 07 11 13 14 15 16 19 23 25 26 27 28 31 35 37 38 39 40 43 47 49 50 51 52 55 59 61 62 63 64 67 71 73 74 75 76 79 83 85 86 87 88 91 95 97
Looks like this would do the trick:
         asNumbers.sort();
            else
         // Move 00 as first string to end of the array with the numbers.
         if (asNumbers[0] == "00")
            asNumbers.shift();     // Remove 00 from beginning of array.
            asNumbers.push("00");  // Append 00 at the end of the array.
      // Remove last string from array if it is an empty string
      // because the file ends with a line termination.
      if(asLines[asLines.length-1] == "") asLines.pop();
      asLines.sort();   // Sort the lines alphabetically.
      asLines.push(""); // Append an empty string to terminate finally last line.
      // The write command below is fast for some lines (50 or 200)
      // but very slow for larger blocks with 5000 or more lines.
      // UltraEdit.activeDocument.write(asLines.join("\r\n"));
      // The alternate version using paste via a user clipboard is always
      // very fast even for larger blocks with thousands of lines.
      UltraEdit.selectClipboard(9);
      UltraEdit.clipboardContent = asLines.join("\r\n");
      UltraEdit.clearClipboard();
      UltraEdit.selectClipboard(0);
However, the script above resulted in "00" at start of a line instead of the end before Mofi modified it. Now it produces the wanted result.
The lines are additionally sorted alphabetically before written back to the active file as requested later.
Thanks!
Gradius
Postby Mofi » Fri Mar 29, 2013 4:59 am
I don't see a problem with the script you posted. It does not delete 00 completely as you first wrote. If a line contains one or more 00, the line has exactly 1 00 at beginning after script execution.
By the way: Depending on the number of lines on which the script is executed the command
can be executed by UltraEdit very fast or very slow as I learned by myself on developing other scripts. The workaround for writing a modified block always fast back into a file is following code:
// Select user clipboard 9 so that Windows clipboard content is not modified.
// Join the lines back to a block in user clipboard 9.
// Paste the block back to file (overwriting a selection).
// Clear user clipboard 9 to free memory.
// Select Windows clipboard before exiting the script.
Postby Gradius » Fri Mar 29, 2013 11:21 am
Hi Mofi,
Correct, it really put 00 at start of each line (when there are one), but I need it to put at the end, since 00 in this case is like 100.
About the added code, I should replace "UltraEdit.activeDocument.write(asLines.join("\r\n"));" by this code?
I still need a solution for "00" to be at the end of line (if present).
Thanks!
Gradius
Postby Mofi » Fri Mar 29, 2013 11:39 am
I modified the script in your post to get 00 at end of a line and pasting the modified block back to file instead of writing it back as this is faster for larger blocks.
Postby Gradius » Fri Mar 29, 2013 11:53 am
Thanks a lot! Is working perfectly! :o
Gradius
