delete some lines contains same text but different num
Postby payton » Sun Jan 06, 2013 1:32 am
Hi!
I am a green hand to scripting.
I have written a script that filter some characters in a text file. The source characters are:
../../../External_delivery/TBSW/BasicSystem/api/bs_lib.h:869: warning: `struct sockaddr' declared inside parameter list
../../../External_delivery/TBSW/BasicSystem/api/bs_lib.h:869: warning: its scope is only this definition or declaration
After run script, the expected result is:
UltraEdit.activeDocument.findReplace.replaceAll = true;
UltraEdit.activeDocument.findReplace.replace("STRING", ""); //How can I write this STRING?
Thankful for all help I can get!
Payton
payton
Re: delete some lines contains same text but different num
Postby Mofi » Sun Jan 06, 2013 11:29 am
If you add at top of the script the commands
UltraEdit.columnModeOff();
UltraEdit.perlReOn();
to define the environment for the script completely and not depending on interal defaults of UltraEdit, the command for removing the file name and line number information and the warning message is:
UltraEdit.activeDocument.findReplace.replace("^.*?:\\d+:.*?: ", "");
^ ... start every search at beginning of a line.
.*? ... any character except new line characters zero or more times non greedy to next fixed character which is twice a colon.
\d+ ... any digit one or more times. (Backslash escaped by an additional backslash because of Javascript string.)
Alternatively you can use also
UltraEdit.activeDocument.findReplace.replace("^(?:.*?:){3} ", "");
(?:...) ... a non marking group.
.*? ... any character except new line characters zero or more times non greedy to next fixed character which is three times a colon.
{3} ... it must be possible to apply the expression inside the non marking group exactly 3 times.
Postby payton » Thu Jan 10, 2013 3:00 am
It works well. Thank u very much.
payton
