Aligning "=" using script in UE v13.00
Postby Dawk » Thu Feb 15, 2007 4:02 pm
After giving up on writing this as a macro, I decided to try doing it with javascript. The following works, although it is a bit slow.
function getpos()
   pos = 0;
   while (UltraEdit.activeDocument.isColNumGt(pos))
         pos++;
   return pos;
UltraEdit.columnModeOn();
var longest = 0;
var pos;
var current;
var padding = "";
UltraEdit.activeDocument.findReplace.find("=");
while (UltraEdit.activeDocument.isFound())
   current = getpos();
   if (current > longest)
      longest = current;
   current = getpos();
   padding = "";
   for (var i = current; i < longest; i++)
      padding += " ";
   UltraEdit.activeDocument.write(padding+"=");
UltraEdit.columnModeOff();
Before:
suggestion = "no idea what to write here"
xp = "quite a bit"
beginning = "hard"
asdf = 1233
// comment line
asdf2 = skumhest
After:
xp         = "quite a bit"
beginning  = "hard"
asdf       = 1233
// comment line
asdf2      = skumhest
Dawk
Re: Aligning "=" using script in UE v13.00
Postby Bego » Wed Feb 21, 2007 8:04 pm
Hi dawk,
I tried to enhance your script by a regexp to replace leading blanks before aligning.
Otherwise you get
a = 12356
bbb = 34566
  ccccccc = 0567567567
 dd = 3344
--> your code
a         = 12356
bbb       = 34566
 dd       = 3344
but I want:
a         = 12356
bbb       = 34566
dd        = 3344
(or with 2 blanks less before the =)
rds Bego
Bego
