Assign Script to buttons
Postby cmgrant » Fri Mar 23, 2007 5:55 pm
Is it possible to assign a specific script to a button on a toolbar?
cmgrant
Re: Assign Script to buttons
Postby Mofi » Sun Mar 25, 2007 4:44 pm
Simple answer: No! (for UE v13.00+4)
Use hot keys and write a feature request email to IDM support.
Postby mwoffenden » Mon Jun 07, 2010 5:52 pm
Is it possible to do this yet? 8)
mwoffenden
Postby Mofi » Tue Jun 08, 2010 12:09 am
Also in UltraEdit v16.10.0.1027 it is not possible to map scripts to buttons on a toolbar. Scripts can be executed only by hotkey or chord (key sequence), from the Scripting menu or from the Script List opened with a click on View - Views/Lists - Script List and set to auto-hide when often needed, but the screen display area needed for the list should be available normally for the edit windows.
