- Code: Select all
// Set UE Application Objects
UltraEdit.ueReOn; // Use UltraEdit Regular Expressions
// Set search variables
//var rexCodeTypes = "% 20[1-2] "; <-- This is what I'm trying to do
var rexCodeTypes = "s*e"; // <-- This is the simple test that doesn't work
// Retrieve and store active document's index
var activeDocIndex = getActiveDocumentIndex();
// Return focus to original document
UltraEdit.document[activeDocIndex].setActive();
UltraEdit.document[activeDocIndex].top();
UltraEdit.document[activeDocIndex].findReplace.regExp = true;
UltraEdit.document[activeDocIndex].findReplace.find(rexCodeTypes);
// Functions -----------------------------------------------------------------
/* Find the tab index of the active document */
tabindex = i;
break;
return tabindex;
Can someone help?
