Selecting some text
Selecting some text
Postby gstola » Mon May 28, 2007 7:41 pm
I need to select some characters. To do so, I wrote the following script, though it selects all the text in the file. Who know how to copy and paste only some bytes? Thank you
UltraEdit.selectClipboard(0);
UltraEdit.clearClipboard();
var i = 0;
UltraEdit.document[1].startSelect;
while (i < 3) {
UltraEdit.document[1].key("RIGHT ARROW");
i++;
UltraEdit.document[1].endSelect;
UltraEdit.document[1].copy();
UltraEdit.document[2].paste();
gstola
Re: Selecting some text
Postby Bego » Mon May 28, 2007 8:13 pm
Errrrr, can you pls post a before and after example ?
No clue what you want to do....
Bego
Postby gstola » Mon May 28, 2007 10:51 pm
lets say, if I have a file containing
0123456789
the script I posted creates a new file containing the same data
what I expected was to have only
012
since I wanted to select only the first three chars
gstola
Postby jorrasdk » Tue May 29, 2007 7:13 am
Edited after Mofis response below
An alternative to moving the cursor with RIGHT ARROW and StartSelect()/EndSelect() is this trick with find and regexp for "any 3 characters":
UltraEdit.ueReOn(); /* Let's use UE's own regexp syntax */
UltraEdit.document[1].findReplace.regExp = true; /* we're going to find data using regular expressions */
UltraEdit.document[1].findReplace.find("???"); /* any 3 characters */
Postby Mofi » Tue May 29, 2007 7:24 am
RIGHT ARROW is enough when selection mode is activated. But gstola has not activated the selection mode, because he as not called the function to activate it. He has only evaluated, if the function startSelect exists.
UltraEdit.document[1].startSelect();
and
UltraEdit.document[1].endSelect();
would work.
gstola, read at forum topic UE Regular Expressions Problem the posts from Sam Hasler and me (Mofi) to understand the difference.
